tnr Posted March 2, 2007 Posted March 2, 2007 Hello, I just bought a Terratec Cinergy 1200 DVB-C tuner. The included Home Cinema software "works", but it finds only three channels because there is not an option for choosing the modulation (that 64-128-QAM stuff). I got a picture for these three channels though. Then I gave a try for DVBViewer... "No hardware available" message appears immediately when I start DVBViewer. By clicking Settings -> Options -> Hardware -> Device.. I can see "Cinergy 1200 DVB-C Tuner (BDA)". Windows Device Manager shows a "Cinergy 1200 DVB-C Capture (DBA)" in addition to the tuner device. Vista is quite vanilla, nothing special installed. DVBViewer: 3.6.1.2 Cinergy drivers: 4.8.17 support.zip Quote
Maketee Posted March 2, 2007 Posted March 2, 2007 Check this thread. Deleting channels.dat file should fix that error message. Can you scan channels? Does it find any? Quote
