Russ Allen Posted March 2, 2007 Posted March 2, 2007 (edited) Hi all, I've just installed DVBViewer for my Pinnacle PCTV DVB-T card, and things were looking really good! However, I could only tune into 33 channels, I was missing a lot of BBC channels for example. After some research, I think I've got a solution. I've used the following two websites: http://www.digitalspy.co.uk/terrestrial/tuning/ http://www.ofcom.org.uk/static/reception_a.../index.asp.html I've then customised my europe.ini file to match the information contained in these two websites, showing the 6 transponders for my nearest transmitter (WinterHill). My Europe.ini file now looks like: [SATTYPE] 1=5000 2=UK-WinterHill [DVB] 0=6 1=754000,8 2=834167,8 3=850167,8 4=842167,8 5=786167,8 6=810167,8 And I now get 65 channels! If anyone's interested, I've put an Excel spreadsheet together which helps to automate this a bit and I've attached it. If people are wary of opening this, I'm guessing with macros turned off all should be okay? I've scanned it with AVG Free 7.5.446, virus base 268.18.5/707 and it came through clear. Hope that all made sense, Russ Edited March 2, 2007 by Russ Allen Quote
Russ Allen Posted March 2, 2007 Author Posted March 2, 2007 Okay, looks like spreadsheet didn't attach - if anyone's interested just msg me. Quote
adriankendall Posted March 2, 2007 Posted March 2, 2007 (edited) Okay, looks like spreadsheet didn't attach - if anyone's interested just msg me. Blackhill transmitter in central scotland use offsets as well can send a transponder file to anyone who wants it. Code is bellow & have attached a copy of my file [sATTYPE] 1=5000 2=Terrestrial (BlackHill) [DVB] 0=6 1=634167,8 2=658167,8 3=682167,8 4=714167,8 5=746000,8 6=826000,8 blackhill.ini Edited March 6, 2007 by adriankendall Quote
sluisga Posted March 11, 2007 Posted March 11, 2007 Is it possible to put the details of Crystal Palace (UK) transmitter please? Many thanks in advance. Quote
mr_chaela Posted March 11, 2007 Posted March 11, 2007 Is it possible to put the details of Crystal Palace (UK) transmitter please? Many thanks in advance. Europe.ini works fine for Crystal Palace, just change line 22 to read:- 22=554167,8 in order to tune BBC HD1 trial. hth Quote
juanv2 Posted March 17, 2007 Posted March 17, 2007 Okay, looks like spreadsheet didn't attach - if anyone's interested just msg me. Hi Russ, May i have the Spreadsheet please thnk you in advance Quote
