Problem With Some Channels
Javichu1984
Hello again!!! After winning the remote challenge, I had a new problem....
Some channels, 3 or 4 of 23 appear only in half screen.....they are deformed and appeared with a big black line on the right....and is no format (16/9, 4/3....)problem.
What it could be?
Thank you a lot!!!
Try to read around it in the forum, this is not a new problem...
As far as I remeber it depends on the Codec/Render in use...
:biggrin:
Thank you a lot Gioxy, I try it yesterday, and the only way to solve it is changing the Overlay mode to Unchanged mode in Video Renderer options, but the problem now in this mode, is that the desktop TV is disable :S
I also check to change the Mpeg 2 Decoder, and selecting the ciberlink powerdvd7 to mpeg2 it works also in overlay, but after changing some channels it crashes.....
What would be the solution?
(I can´t find nothinh in the forum with this problem.....)or wich keywords do I have to use?
Thank you a lot.
Post some more informations using the SupportTool you can find at bottom of this post
:wacko:
Thank you a lot Gioxy! I have finally the problem solved....
I made an upgrade to the Cyberlink codec, and now it works! :bye:
Thank you a lot for your help!
(w00t)
