Howto Edit Osd-menu In Dvbviewer Pro 3.6?
Vies2
Hi everyone,
Is there a way to edit OSD-menus in DVBViewer pro 3.6.x? There is OSD-menu edit program in member section, but it seems to be for a DVBViewer 3.1, and it keeps trying to find file that doesn't exist in DVBViewer 3.6.x
I'm trying to get a launcher button for joost in my DVBViewer menu. One way is to make command group in girder that shutsdown DVBViewer, starts joost and when it is shutdown, launches DVBViewer again.
But launch button in DVBViewer would be better. So any way to do that?
Vies
The OSD-Menu Editor is the right tool.
If you delete the menuedit.lng the OSD-Menu Editor turns to English.
Open the wight windowdef.xml (About>Info..>Versionsinfo-> the blue link) you have to close the DVBViewer now.
Edit>Add Programme select the start.bat because you like to open the Application and close the DVBViewer at the same time you should use a .bat file.
start.bat
start "" C:\Programme\DVBViewer\DVBViewer.exe -x16383
start "" C:\...   ...joost.exe
With the -X parameter you could use all ids from the actions.ini
The OSD-Menu Editor is the wright tool.
Good combination of "wrong" and "right" :bounce: What you mean is "the right tool" . BTW: my english is also a bit "strange" sometimes... :biggrin:
