visuel Posted March 10, 2007 Posted March 10, 2007 Hello dvbViewers, I am trying to get MediaHighway(?) information about the dutch CanaalDigitaal channels in the EPG window. At the moment I only see info about current and next program of each channel in this window, but I think that you can get a lot more (two weeks or so?) On the board I see a lot of contradictions about "do not recieve EPG" or "do receive EPG" checkbox. Don't know what to fill in at frequency panel. I tried to find it at the internet though! But nothing helped me. Is there anybody who can help me further? Extra info: I am running 3.6.0.2 on a Skystar1-CI in Vista with Cyberlink Video and Audio decoders. Everything works fine, also the CAM to descramble the dutch channels. Regards, Victor Quote
Tjod Posted March 11, 2007 Posted March 11, 2007 You have to adding the MHW Transponder from Canaldigitaal 12515 h (i choose Mediahighway 1 but did not know the difference to Mediahighway 2) on Options>SiehFern/MHW and activate it on Options>EPG/Teletext. Than you go to a channel on this Transponder for example FunX (radio) and the receiving of the MHW starts. In my test i only got EPG for two days 12.03 and 18.3 than it says receiving finesh. I did not know if i have configured some thing wrong or Canaldigitaal send only this data at the moment or something go wrong in DVBViewer. Quote
visuel Posted March 11, 2007 Author Posted March 11, 2007 You have to adding the MHW Transponder from Canaldigitaal 12515 h (i choose Mediahighway 1 but did not know the difference to Mediahighway 2)on Options>SiehFern/MHW and activate it on Options>EPG/Teletext. Than you go to a channel on this Transponder for example FunX (radio) and the receiving of the MHW starts. In my test i only got EPG for two days 12.03 and 18.3 than it says receiving finesh. I did not know if i have configured some thing wrong or Canaldigitaal send only this data at the moment or something go wrong in DVBViewer. Thank you Tjod, I followed your advise and I get the same results as you! EPG data for today, tomorrow and some for 18/3. But what do you mean with "then it says receiving finish". Is there some mesage or pop-up? Thanks again. Quote
Tjod Posted March 11, 2007 Posted March 11, 2007 (edited) Yes i got a OSD message "Finished reading MHG EPG". Edited March 11, 2007 by Tjod Quote
visuel Posted March 11, 2007 Author Posted March 11, 2007 (edited) Yes i got a OSD message "Finished reading MHG EPG". So far, I did not see that. Maybe I have to flag an OSD checkbox somewhere? After I installed the 3.6.1.2 version, I saw the OSD message. I think everything works properly now... Thanks for helping. Victor Edited March 11, 2007 by visuel Quote
