Dvbviewer Video Jump-feature
HD.
So it seems that you cannot get FF/REW during Recordings playback. Well, Video jump feature is quite OK, just one problem.
When i try to jump for example 1min. (10sec-30sec-1min) with remote control, the result is usually 10sec-10sec-10sec. Remote is sending commands a bit slower than a keyboard, and DVBViewer is WAY too fast to jump.
So is there any way to adjust the time that it waits for the next key (1,5sec perhaps) before doing the jump?
I've looked through the settings several times and I cannot find anything useful. So if someone has any good trick for me, it would be great.
Hello,
how do you use the remote control, WinLirc or Girder or?
PS: if you disable "Use DVBSource for Mpeg Files" in Options -> DirectX, you can FF/REW, but you can't play files they recorded at the same time and other problems which you can have without this option. :bounce:
:wacko:
Hello,
Bit complex, Terratec Cinergy 2400iDT's Receiver (and software) with Logitech Harmony 525.
PS: if you disable "Use DVBSource for Mpeg Files" in Options -> DirectX, you can FF/REW, but you can't play files they recorded at the same time and other problems which you can have without this option. :wacko:
Thanks, gotta try how this works.
Well this didn't work very well but thanks anyway.
