Skipping (+10,+30 Etc) Takes A Long Timet To A/v Sync Again
Mach5
Configuration:
Amd Athlon 64 3500+, 1GB, Fujitsu-Siemens Scaleo T,
XP, sp2
MB: Asus A8NE-FM
GC: GeForce 6600, FW 81.98
DVB-T: TechnoTrend Budget 1500T+Conax CAM and Nebula PCI DigiTV
DVBViewer: 3.6.1.2
Setup.xml attached
And the problem itself:
When playing recorded file and try to skip (+-10,30,60s) forward/backward it takes between 1s-> 35s to sync a/v and continue playback. If I use Media Player, Viplay or VLC player -> no problem with skipping forward/backward.
Press skip +30s -> video stops to still image and audio keeps going for awhile -> audio stops -> video starts working again -> a/v are synced and working as expected.
Any ideas where to tweak?
setup.xml
<entry name="Videocodec"><System Default></entry>
I guess you have installed ffdshow, and it is used as "system default" video decoder (I experienced the same behaviour with ffdshow). Select a specific (and different) video decoder under Options -> DirectX.
ffdshow was the default decoder and after testing every options best and fastest option on my system is
"Videocodec">InterVideo Video Decoder
So problem solved.
Thanks
