Error At Install
Hi i've just installed windows vista and i wanted to install DVBViewer as well, but at the beginning ( where it identifys wpp & directx ) is sais that i have to install wmp 9 or higher, though im having wmp 11. any ideas of how I could solve this ? :bye::dvbviewer:
You are taking about DVBViewer TE (wrong part of the board).
Did you use 4.4.1 Beta Version (06.03.2007)
I did not have this problem.
You could try edit the ..\441B20070306web\Install\setup.ini and insert:
CheckMediaPlayer=FALSE
