Com Equivalent For Cmdline Param "-c"
UPollaehne
is there a COM equivalent of the command line parameter "-c" which sets the currently displayed channel?
I've browsed through the COM docs but was not able to find some property or function to achieve this. Is it me or is there really no function to change the currently tuned channel?
You're looking for idvbviewer.CurrentChannelNr
Hi Lars,
Thanks. There the "Read only Property." statement is missing. ;-)
Hm, maybe a bit too fast. ;-)
What is this channel number?
Or better: If I have the channel list which property gives me the channel number to be used for currentChannelNr?
have a look at the channelcollection interface. function GetNr(const ID: WideString): Integer;
or if you use the Getchannellist: ChannelNr=Position in list.
I did not dare to hope for an answer that easy to implement. Thanks again.
