Which Decoder For H264...
dbercot
I've just bought DVBViewer (which is great ;-)), but I have a problem with H264 channels.
When I want to watch one, DVBViewer crashed...
I'd like to have a light configuration, so, I've just installed DVBViewer and ffdshow-tryout [http://ffdshow-tryout.sourceforge.net/].
In DirectX section, I said to use ffdshow for all codecs (audio & video), include H264.
And it is the only decoder for H264 I have on my system.
I've been told about CoreAVC, but it seems not to be get [http://www.coreavc.com].
Moreover, zapping is very very long...
Do you have any advice for me ?
Thank you very much.
David.
ffdshow does not work for DVB-S HD. You need to use either PowerDVD 7 (this came with my technotrend S2-3200 DVB-S2 card) or CoreAVC.
Sorry but I have not seen your answer before ;-)
OK. It was the conclusion I had found ! CoreAVC seems to be great...
David.
