Export And Import Ini
Smallish Zulu
Hi all,
Is it possible to export & import from/to DVBViewer INI formatted channels by COM or Cmd Line?
Thanks.
Edited by Smallish Zulu
Pleas do not ask such things via PM (Send Message).
I do not know it if it is possible, i didn't used the COM Interface.
And it is not necessary to make three topic for nearly the same thing (Com Disecq Settings and Com Channels.dat).
Here you find a sample which reads channellist and EPG.
It is quite simple to export or import channels with the com interface, at least ff you have some programming experience. All you have to do is to get or set the channel entries (this is explained in the com sdk).
Christian
You can not import channels only export (by doing it yourself from the channellist via com).
Please do not ask such things via PM (Send Message).
@Tjod: You are not the only one who got such a PM. :)
Other topics started by Smallish Zulu deleted.
@Smallish Zulu: You are warned now. If you try to push a request again in this way, you may get excluded from this forum.
