Dvb Subtitle Timing When Playing .ts File
Norpa
DVB subtitles show 2-3 seconds too early when playing .ts file in DVBViewer. Timing is correct on live broadcast and also when I make dvd out of the .ts file using ProjectX and IfoEdit.
This is my experience also. Version 3.6.1.20, DVB-T teletext subtitles.
Timing is correct on live broadcast until Paused, then subtitles too early after resuming from Paused.
Edited by alfw
  • 3 weeks later...
I have got also the problem : "The teletext subtitles displays about 2 seconds too early when I play TS-file."
Is that problem fixed ? What is the solution ?
I've got timing problems also. Although this time with live broadcasts. Any idea what is causing this? I get subs 2-3sec too early too.
I live in finland and the dvb-card is a terratec cinergy 1200C
