Javichu1984 Posted March 25, 2007 Posted March 25, 2007 Hi again!!! I finally get DVBViewer works perfectly with the Hauppauge HVR-1300 with mpeg-2 encoder. But there is only one problem....until yesterday I have no EPG data.....I explain....when you change the channel, at the botton a pop up window shows the channel info, program, next program.....well, so the thing is that until yesterday I don´t have this info for a lot of channels.....and they also don´t have info in the timeline, but when I open the EPG window, and the individual channel info, there is EPG info on each channel!!! Why suddenly it stops working? Thank you a lot. Quote
Javichu1984 Posted March 25, 2007 Author Posted March 25, 2007 Ohhh, I check in another DVB of and there is also no EPG info in this channels, so is not my problem, is TV problem.... The thing is that here in Spain the EPG works really really bad...... Sorry for my question :S momentaniously is solved! Saludos from Spain!!! Quote
mitrasgu Posted March 29, 2007 Posted March 29, 2007 Ohhh, I check in another DVB of and there is also no EPG info in this channels, so is not my problem, is TV problem.... The thing is that here in Spain the EPG works really really bad...... Sorry for my question :S momentaniously is solved! Saludos from Spain!!! Does work EPG in DVBViewer in Spanish Sat to you? It works only in some channels but with others DVB it works. I am spanish too and if you want we can exchange our experiences with DVBViewer in spanish. mitrasguborrar@gmail.com Thanks. Quote
Javichu1984 Posted March 31, 2007 Author Posted March 31, 2007 (edited) Does work EPG in DVBViewer in Spanish Sat to you? It works only in some channels but with others DVB it works. I am spanish too and if you want we can exchange our experiences with DVBViewer in spanish. mitrasguborrar@gmail.com Thanks. Bueno, pues en español , mi mail es javichu1984@hotmail.com, si tienes messenger agrégame y hablamos. Saludosss Edited March 31, 2007 by Javichu1984 Quote
Tjod Posted March 31, 2007 Posted March 31, 2007 Some Spanish TV stations transmit MediaHighWay EPG on Astra 10847 V. To use it you have to enable MediaHighWay EPG (Options>EPG/Teletext->Receive MediaHighWay EPG). And than you have to stay some seconds on a channel on this transponder (frequency). Quote
Javichu1984 Posted March 31, 2007 Author Posted March 31, 2007 Ohh yes sorry, I forget to answer this..... I use the DVBViewer for TDT (DVB-Terrestrial) not satellite, and the EPG is there but in the satellite I don´t know, but Tjod solve this! Thank you a lot! Quote
