dbercot Posted March 25, 2007 Posted March 25, 2007 Hi again, With DVBViewer, satellite channels are OK (both SD and HD ones). Playing videos is ok too ! But I can't play DVD !!! When I launch one, it is very jerked... My configuration : DVBViewer, ffdshow-tryout and CoreAVC ! Nothing else !!! Do you have any idea ? Thank you very much. David. Quote
CiNcH Posted March 25, 2007 Posted March 25, 2007 DVD's are crypted. You need decoder filters that can handle CSS, like the filters from InterVideo WinDVD or CyberLink PowerDVD. Quote
dbercot Posted March 25, 2007 Author Posted March 25, 2007 DVD's are crypted. You need decoder filters that can handle CSS, like the filters from InterVideo WinDVD or CyberLink PowerDVD. Yes, I understand, but I can see the DVD. The only problem is that it is not fluid... Do you think my problem comes from a CSS filter ? Thank you very much. David. Quote
CiNcH Posted March 25, 2007 Posted March 25, 2007 If it was CSS you wouldn't see too much of the video. In this case I would say that ffdshow is causing the trouble. I would try different decoder filters anyway... Quote
