Time Shift, Hd And File's Size...
dbercot
Two days ago, I've tried time shift in DVBViewer on a HD channel.
I've pushed the "pause" button and started to watch the film 15 minutes later.
Everything was ok during about an hour and a quarter. Then, the screen freezed !!!
I had a look in the folder and the size of the file was 5,4 GB.
Do you know if there is a limitation in time or in size for the time shift ? May be it should be because of the size, very big in HD ?
Should I said to DVBViewer to cut in many files ?
Thank you very much.
David.
Hello,
no limitation in size or time.
But you can watch a file which is recorded in same time, OSD -> Recordings.
With this you have a limitation of time if you make a timer for one program.
:bye:
Hello,
:bye:
Hum, so it seems to be a bug, no ?
I'll make other tries...
Thank you.
David.
