UPollaehne Posted April 1, 2007 Posted April 1, 2007 Hi, minimizing and restoring the DVBViewer window with SendCommand worked nicely but then I decided to disable the OSD since I do not use it. The result is that minimizing and restoring the window by sending the corresponding commands does not work anymore. Is this the intended behaviour? The version I use is 3.6.1.2 Quote
UPollaehne Posted April 1, 2007 Author Posted April 1, 2007 Please explain the reason for this behaviour. Quote
