Osd Skin
Hi all,
I want to make an OSD Skin like New Def or Frosch. How can I do that? I looked at the members area, found the OSD Skin Editor but I can not figure out how I can connect a button to a command.
For example: There are colored buttons like red, blue, green, yellow. In frosch skin under channels menu, red has a different function then New Def skin. I want to change button functions and want to create a new OSD depending on these 2 skins.
Thank you for the helps.
The OSD-Skin Editor you will find here.
Just open a existing skin and change it.
OK I can make new designs. However, how can I create events?
For example, I want to add a new button to jump channels 10 by 10. I made the design. But I dont know how to add the code ;)
