Cancell A Recording Froschs Skin And Mce Remote
I have recently installed Froschs skin - and I must say that I am impressed with it. I am currently using it with an MCE remote using plugins from the member area. My problem is when I have used my MCE remote to record a program in the future but I then change my mind and I want to cancel it. Is there anyway of canceling it with the remote?
OSD-Menu -> Timer -> Select timer -> one of the colorbuttons deletes it (don't remember which)
Thank you. I had not enabled it in the OSD Menu.
