sebastianratz Posted April 8, 2007 Posted April 8, 2007 Hi, I've got a shoutcast server running in my LAN and i would like to connect to that shoutcast server with DVBViewer, so that the people on the LAN can listen to the mp3 stream in winamp. Is there any chance to do this by a plugin? If not, is it very hard to create a plugin capable of doing so? Quote
Tjod Posted April 9, 2007 Posted April 9, 2007 I do not know shoutcast. But i see tow possibility haw it may be work. You use the Audio Recorder Plugin to record in mp3. And open the file during recording. The DVBViewer is able to stream to VLC media player (NstStream plugin) may be you could connect from VLC to shoutcast. I do not know how complicate it is to build a plug in. Quote
moremax Posted June 3, 2007 Posted June 3, 2007 Hi Tjod, ich glaube was er meint ist sowas wie Shoutcaster bei Dreamboxen, mit dem Plug kann man Internetradio im MP3 Format empfangen. Das Plugin von IHAD hat vordefinierte Senderlisten, die über Genere auswählbar sind. Quote
