dhs Posted April 10, 2007 Posted April 10, 2007 Ok, this must be the dumbest question ever... I launch DVBViewer, hit "enter" and no osd. Checking options, it's corretly set to open when Enter is pressed, but nothing. If i set the OSD clock to, for example, F1, it works. So, why no OSD? Quote
Tjod Posted April 12, 2007 Posted April 12, 2007 Pleas post you support.zip and include you *.remote file with your saved key settings. Quote
