3.6.1.20 Changelog ?
Im Downloadbereich gibt es eine 3.6.1.20. Wo finde ich die Info, was geändert wurde ?
wie wäre es den mit der changelog.txt aus dem Installationsverzeichnis?
Was könnte den der Link im Mitglieder-Bereich bedeuten, der den Namen Changes trägt?
Aber für alle die nicht wollen oder können, bitte schön.
Version 3.6.1.20
[*] Fix: Vista Titlebar was not hidden in fullscreen mode
[*] Add: new turkish language
[*] Add: partially CI support for KNC1 Adapters (KNCBDACTRL.dll required)
[*] Change: removed post processors
Version 3.6.1
[*] Fix: ATSC EPG works again
[*] Fix: Shoutcast Filter is now part of the installer again
[*] Fix: game gravitron works now
[*] Change: Channellist is saved automatically after channelscan.
[*] Change: Timers.xml is saved after most changes.
[*] Change: Favorites are written now when pressing the save button.
[*] Fix: knc detection
[*] Fix: MultiCore CPU settings did not worked properly.
[*] Fix: DVD-Prev Chapter was not working.
[*] Change: Forms outside the monitor are now repositioned
[*] Add: Popup menu in Mainwindow now shows the filterlist.
[*] Change: All filters are listed in Filterlist.
[*] Fix: COM: ChannelID was still calculated the old way.
[*] Change: On saving a backup of Timers.xml is created.
[*] Change: 10x tuning limit removed
[*] Change: USALS (E/W, N/S now possible).
[*] Change: <Auto> now replaced with <System Default>.
[*] Change: Subtitles: Now there is always a entry Subtitles -> None, in case a channel transmits only "No subtitles available" (ttx ZDF). Before you couldn't disable this, case it was not marked as subtitle page...
[*] Change: TTx Subtitles: On switching channel now subtitles are cleared.
[*] Fix: Wrong AC3 decoder detection.
[*] Fix: Instancehandling in Vista.
[*] Fix: Mp3 Decoder handling.
[*] Fix: Skystar 2 <-> Server4PC conflict.
[*] Fix: Filedevice: Didn't work.
[*] Change: Plugins can now retrieve the whole multiplex
Version 3.6.0.2
[*]Fix: Split on TS files didn't work.
[*]Fix: TTX subtitles were not save correctly in db.
[*]Fix: Favourites menu didn't work properly.
[*]Add: Updated languages: Suomi, Danish, Polish.
[*]Fix: EPG-external: external epg was sometime not recognized correctly.
[*]Fix: Systemerror code 5 fixed.
[*]Fix: actions.ini added again to setup.
[*]Fix: ttapi.dll added again to setup.
Version 3.6.0.0
[*]Add: Added recordingservice.
[*]Fix: EPG-Window: Fixed "&" was replaced by "_" in Timeline.
[*]Add: Recorderwindow: Added play running recording to contextmenu.
[*]Add: Recorderwindow: Added doubleclick on running recording switches to the channel the timer is recording.
[*]Fix: COM-Events: Fixed several glitches.
[*]Fix: Siehfern: Fixed endless loop in receiving due to too small buffers.
[*]Add: Channels/EPG: Added selection for EPG-Source in chaneleditor.
 The source:
- Dvb script: Fixed addrec.vbs not gets called.
[*]Fix: DVB-S2 should now work in the DVBServer too
[*]Udated: Language: Italiano thanks to Gioxy.
[*]Udated: Language: French thanks to Etienne
[*]Udated: Language: German and Englisch thanks to Lars_MQ;)
[Fix] Netstreaming Plugin: Now the current netstreaming plugin is in the package.
[Updated] EPG-Window:
The EPG window is  completely reworked. Now you can sort the columns like in the recorder window by dragging then in the wanted order. If you rightclick a columnheader, you can hide unwanted columns in the popupmenu. Several columns were added and are now sortable.
All pages now have a popup menu with the currently valid actions. The new Copy button and Copy Menu Item copies the selected entry into the clipboard. The Time search and the EPG search have been integrated into the EPG Window and can be activated via the popup menü or via the two toggle buttons in the upper right of the window. The Timesearch works in the What's Now and Timeline window, the Search automatically toggles to the What's Now window to display the results.
The predefined times in the What's now Window formerly directly in the Popupmenu of this page were moved to a submenü. Instead you can now select the predefined times from the OSD-Timeline (noon, afternoon, evening, late evening). To set up this values go to OSD-Menu -> HTPC - Settings - Timeline.
Version BETA 3.5.0.10 to BETA 3.5.0.24
[*]Fix: OSD Preview problems in GDI Skin mode
[*]Fix: Problem with PMT Parsing of some danish cable channels
[*]Add: 2 small OSD games
[*]Fix: Images of toolbuttons.
[*]Fix: Pinnacle HDTV fixed (again) DiseqC hopefully finally working...
[*]Change: Improved internal channellogo handling.
[*]Add: Premiere EPG for Premiere Direct portal.
[*]Change: VMR: Added a workaround for buggy Nvidia. Please check DirectX-Options.
[*]Add: Hardware Options: added a delete device button. simply select the device in the list and press delete.
[*]Fix: Hardware: Nova-s plus and other connexant chip based card: diseqC is supported.
[*]Add: EPG: added more informations from the extended descriptions if available.
[*]Add: Recording window: The timerlist in the recording window now has a configurable header. You can show/hide columns via the header popup menu (right click with mouse on header) and you can sort the columns the way you want them (via drag'n'drop). There are also two new columns: Day and Duration. The day from the date field was removed.
[*]Add: Internal Winlirc Plugin: The internal winlirc plugin has now a options page in the option/input/inpputplugins section (select plugin und press options). You can adjust the winlirc host and port there. Normally there are no changes required.
[*]Change: VMR OSD Filter: The VMR OSD Filter has been improved. Now there should be no problems with HDTV channels and not fitting OSD. If you had problems with the VMR OSD try this version. All you people suffering NVidia's wraith, I don't think it will fix nvidia's bugs, but you can try...
[*]Change: Channellist: The channel list now synchronises with the current channel, if the window is open and the channel changed via remote, favourites or keyboard.
[*]Change: OSD-MiniEPG: "No data available" is now displayed if no epg data is available. If you don't want this, simply search for this text in the language file and change it to an empty string.
[*]Add: Vista Menustyle: This is nothing special, but i liked the design while testing the DVBViewer family under the new OS. Just go to Options->General->Appearance
[*]Fix: Skinmode under Vista: Under the latest Release Candidate the old skin engine caused an exception.
- Netstreaming Plugin:
The Netstreaming Plugin is now capeable of streaming the whole transponder. You can activate it in the plugin options. It is not advised to use this for a WLAN (at least it doesn't work with my 54 MBit WLAN). And remember encrypted channels stay encrypted, only the one played back in the DVBViewer will be decrypted via CAM/CI.
Und wie komme ich da ran vor der Installation. Ich installiere ungern die Katze im Sack ? ;)
Danke für's Changelog.
