Bluestraw Posted April 16, 2007 Posted April 16, 2007 I'm using two TT USB Sticks, with the latest BDA drivers. They work fine in MCE as a dual tuner setup. I am now trying to use them instead in DVBViewer in the same machine. DVBViewer is working fine with a DVB-S2 card already in that same machine. However, a Channel Scan on the Terrestrial frequencies only finds 1 MUX, instead of the 5 muxes that work properly in MCE. Even on that 1 mux, it seems the signal quality is somehow poor, as if there is not enough power to the tuner? Any help would be much appreciated! support.zip Quote
