Lyrics
[dba]LaSepp
Hello :angry:
I recently downloaded some lyrics for my MP3s. Now I think it would be a good feature to have them displayed in OSD while the MP3 is playing.
It would be best, if they were loaded from a central directory or if present from the directory where the MP3 is.
Scrolling could be made by the OSD up + down keys.
so for example:
while playing C:\musik\Deine Lakaien - Where you are.mp3
it would display C:\musik\Deine Lakaien - Where you are.txt
while the text file might also be located for example at C:\lyrics\
Hope I could express that the way I think :D
--LaSepp
  • 1 month later...
Guest DAvenger
Would make a nice module for DVBViewer v2 B)
Guest hackbart
Hey, even possible at the moment :lol: Just take a look inside the API and you will find a cool OSD Interface, which allows to put any useful text inside.. I forgot a feature to retrieve the current position in a mediafile, but it will be definitively added B) in the next release..
Cheers
Christian
Guest DAvenger
Sounds good. It's sad that there isn't any Radio station broadcasting lyrics streams B) But .... things may change soon :lol:
