Dean Posted April 20, 2007 Posted April 20, 2007 Hello.... Can anyone tell me if it is possible to change the 'Next' value ' >>| ' from the transport popup to something other than the default 60 seconds? ie. I wish to be able to seek forward in much larger steps when playing back media. I tried examining the 'setup.xml' file, but it doesn't seem to contain any setting for seeking forward. Just wondering if the above is possible?, and if so, is it also possible to 'long' seek forward with a keyboard shortcut? ..cheers.. ..Dean.. Quote
dezzy Posted April 20, 2007 Posted April 20, 2007 See recent thread that helped me: http://www.DVBViewer.info/forum/index.php?showtopic=17904 Quote
Dean Posted April 20, 2007 Author Posted April 20, 2007 See recent thread that helped me: http://www.DVBViewer.info/forum/index.php?showtopic=17904 Thanks! That helped out a lot for regular fast forward and rewind, but was interested in what DVBViewer calls 'Next' which seems to be a fixed 1 minute skip. Is there a comparable XML command entry name for this 'Next' function? ..Dean.. Quote
