Pdvd 7.0 Vs 7.3 Dlx With Dvbviewer & Tt 3200 ?
Rittberg
Hi.
When installing the TT S3200 drivers, the PDVD 7.0 codec are installed,
In order to playback smoothly the new formats - HD DVD & BD we have to install PDVD 7.3 DLX, the new version will overwrite the 7.0 codecs.
Is there any problem with DVBViewer & TT 3200 and the PDVD 7.3 codec?
Is there any advantage or disadvantage using the new codec with DVBViewer compared to the previous ones?
Thanks for your input.
I don't have 7.3, but I've read that the H.264 codec coming with 7.3 version is even worse qualitywise (they say it has banding issues). For the use with DVBViewer it works just the same AFAIK.
