Missing Osd Rec When Recording
patti
Hello, I had to reinstall DVBViewer from scratch and after that the red REC notification does not stay on upper right corner of the screen when I record something. It appears when I start a recording either manually or with timer but then it disappears after a few secs. I have searched through the settings but have not found an option to make it stay put. This worked with the same version (3.6.1.20) before reinstalling. Help?
Edited by patti
I just have the German version, but you will find it:
Options - Recorder - "Aufnahme signalisieren" (Left, second item)
Hey, thanks, it works now! The Finnish translation is not at all clear on this setting.
