miro111hrzg Posted April 27, 2007 Posted April 27, 2007 Regard. I have a problem with matching my remote control to work with the DVBViewer. TV Card is pinnacle PCTV USB Pro with MINI Remote Control. I tried almost all remote applications and I couldn't get them to work with mini remote. the only one who worked is PCTV Remote. PCTV Remote is a Small application which comes with Pinnacle Media Center and even can work if media center is not installed. So I deleted media center because I use DVBViewer , but left PCTV Remote to run in the bacground. My remote really works with that tool for shure, but the main problem is - I don't know how to type exactly code to make it useful with DVBViewer. All I know is I must to configure /type correctly code in PROFILES.INI file which is matched with PCTV Remote: can someone please tell me what I must to type to make some or all buttons to work correctly with DVBViewer? here is original profiles.ini file Thank you. ; ; ; [default] ; start PMC with Remote Type A ( 2ft TV ) key38=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe ; start PMC with Remote Type A ( 10ft main menu ) ; key47=EXEC ..\..\..\MediaCenter\PMC.exe | -10ft -full key29=EXEC ..\..\..\MediaCenter\PMC.exe | -10ft -full ; ; start PMC with Remote Type B ( main menu ) key1006=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full ; ; start PMC with Remote Type B ( 2ft TV ) key1041=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe ; ; Autorun ;HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run autorunkey=PMCRemote ; ; hardware ID: -1 = autodetect ; 0 : COM IR ; 2 : PCTV Deluxe USB IR ; 3 : PCTV USB2 IR ; 4 : PCTV 300i Stereo PCI IR ; 5 : PCTV 100i Stereo PCI IR ; 6 : PCTV 200e USB IR ; 7 : PCTV 310i IR ; 8 : PCTV 110i IR ; 9 : PCTV 400e USB IR ; 10: Pinnacle Remote USB IR ; 11: Pinnacle 3010i IR ; 12: PCTV 60e USB IR ; 13: PCTV 310e USB IR ; 14: PCTV 7010iX IR ; 15: DVB-T USB stick IR ; 16: PCTV Dual DVB-T Pro IR ; 17: PCTV Dual Sat Pro IR ; 18: PCTV Hybrid Card IR ; 19: PCTV Sat Pro IR ; 20: PCTV 260e USB IR ; 21: PCTV Sat Pro USB IR ; 22: PCTV HDTV Sat Pro USB IR HWID=24 port=1 ; -------------------------------------------------- ; NEW: protocol and code mapping override ; currently used by AnyTV/ComboT platform devices ; and Gimly ; code mapping also used by Deltron IR device ; -------------------------------------------------- ; protocol={nec|pcle_rc5|pcle_rc6|pcle_rcm} ; keymap={pcle_rcm|t003_rc5|pcle_rc6|mini_rc5|pcle_rc5} protocol=pcle_rc5 keymap=mini_rc5 rc_id1=0 rc_id2=0 rc_filter=1 ; ; [Pinnacle Media Center] ; ;*************** ; Remote Type A ;*************** ; ; FastForward key7=KEYBOARD f+^f ; Stop key11=KEYBOARD s+^s ; Play key13=KEYBOARD p+^p ; FastRewind key14=KEYBOARD r+^r ; Volume down key15=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key79=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key19=KEYBOARD ALT+RIGHT+^RIGHT+^ALT ; pause key21=KEYBOARD BLANK+^BLANK ; back or jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key22=KEYBOARD ALT+LEFT+^LEFT+^ALT ; page up or channel up key23=KEYBOARD PGUP+^PGUP key87=KEYBOARD PGUP+^PGUP ; EPG key24=KEYBOARD F8+^F8 ; LiveTV key25=KEYBOARD F5+^F5 ; select key26=KEYBOARD ENTER+^ENTER ; volume up key27=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key91=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key28=KEYBOARD PGDN+^PGDN key92=KEYBOARD PGDN+^PGDN ; Menue or settings key29=KEYBOARD ALT+m+^m+^ALT ; toggle list/thumbnail view key30=KEYBOARD ALT+c+^c+^ALT ; toggle repeat key31=KEYBOARD ALT+b+^b+^ALT ; last channel; toggle between the last two channel (viewed >=10sec) key37=KEYBOARD ALT+l+^l+^ALT ; goto TV key38=KEYBOARD F5+^F5 ; capture key39=KEYBOARD c+^c ; goto teletext key41=KEYBOARD F6+^F6 ; goto radio key42=KEYBOARD F7+^F7 ; get info key43=KEYBOARD ALT+i+^i+^ALT ; fullscreen key45=KEYBOARD ALT+f+^f+^ALT ; toggle shuffle key46=KEYBOARD ALT+a+^a+^ALT ; turn off key47=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 and AV selector key58=KEYBOARD 0+^0 ; navigate : right key59=KEYBOARD RIGHT+^RIGHT ; mute audio key60=KEYBOARD m+^m ; navigate : left key61=KEYBOARD LEFT+^LEFT ; navigate : down key62=KEYBOARD DOWN+^DOWN key126=KEYBOARD DOWN+^DOWN ; navigate : up key63=KEYBOARD UP+^UP key127=KEYBOARD UP+^UP ; ; ;*************** ; Remote Type B ;*************** ; ; FastForward key1036=KEYBOARD f+^f ; Stop key1038=KEYBOARD s+^s ; Play key1047=KEYBOARD p+^p ; FastRewind key1034=KEYBOARD r+^r ; Volume down key1044=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key1108=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key1039=KEYBOARD ALT+RIGHT+^RIGHT+^ALT ; pause key1035=KEYBOARD BLANK+^BLANK ; jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1037=KEYBOARD ALT+LEFT+^LEFT+^ALT ; back ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1013=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key1015=KEYBOARD PGUP+^PGUP key1079=KEYBOARD PGUP+^PGUP ; EPG key1042=KEYBOARD F8+^F8 ; LiveTV key1041=KEYBOARD F5+^F5 ; select key1021=KEYBOARD ENTER+^ENTER ; volume up key1043=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key1107=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key1016=KEYBOARD PGDN+^PGDN key1080=KEYBOARD PGDN+^PGDN ; last channel; toggle between the last two channel (viewed >=10sec) key1045=KEYBOARD ALT+l+^l+^ALT ; goto TV key1041=KEYBOARD F5+^F5 ; capture key1046=KEYBOARD c+^c ; goto teletext key1040=KEYBOARD F6+^F6 ; goto radio ; ---------- no assigned button ----- ; toggle shuffle (red button(A)) key1009=KEYBOARD ALT+a+^a+^ALT ; toggle repeat (green button() key1010=KEYBOARD ALT+b+^b+^ALT ; toggle list/thumbnail view (yellow button©) key1011=KEYBOARD ALT+c+^c+^ALT ; get info (blue button (?)) key1012=KEYBOARD ALT+i+^i+^ALT ; fullscreen key1008=KEYBOARD ALT+f+^f+^ALT ; multi station preview ; ---------- no assigned button ----- ; turn off key1002=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key1022=KEYBOARD 1+^1 ; numeric key 2 key1023=KEYBOARD 2+^2 ; numeric key 3 key1024=KEYBOARD 3+^3 ; numeric key 4 key1025=KEYBOARD 4+^4 ; numeric key 5 key1026=KEYBOARD 5+^5 ; numeric key 6 key1027=KEYBOARD 6+^6 ; numeric key 7 key1028=KEYBOARD 7+^7 ; numeric key 8 key1029=KEYBOARD 8+^8 ; numeric key 9 key1030=KEYBOARD 9+^9 ; numeric key 0 and AV selector key1032=KEYBOARD 0+^0 ; navigate : right key1020=KEYBOARD RIGHT+^RIGHT ; mute audio key1001=KEYBOARD m+^m ; navigate : left key1019=KEYBOARD LEFT+^LEFT ; navigate : down key1018=KEYBOARD DOWN+^DOWN key1082=KEYBOARD DOWN+^DOWN ; navigate : up key1017=KEYBOARD UP+^UP key1081=KEYBOARD UP+^UP ; aspect ration (red button (A)) key1009=KEYBOARD a+^a ; home or PMC start key1006=KEYBOARD ESC+^ESC ; c/n key1031=KEYBOARD CTRL+c+^c+^CTRL key1095=KEYBOARD CTRL+c+^c+^CTRL ; del key1033=KEYBOARD CTRL+d+^d+^CTRL key1097=KEYBOARD CTRL+d+^d+^CTRL ;**************************** ; Remote Settings for HTML Plugin interface ;**************************** [Pinnacle MediaCenter] key47=KEYBOARD CTRL+SHIFT+q+^q+^SHIFT+^CTRL key29=KEYBOARD CTRL+SHIFT+w+^w+^SHIFT+^CTRL key25=KEYBOARD CTRL+SHIFT+e+^e+^SHIFT+^CTRL key19=KEYBOARD CTRL+SHIFT+t+^t+^SHIFT+^CTRL key46=KEYBOARD CTRL+SHIFT+z+^z+^SHIFT+^CTRL key31=KEYBOARD CTRL+SHIFT+u+^u+^SHIFT+^CTRL key43=KEYBOARD CTRL+SHIFT+i+^i+^SHIFT+^CTRL ;key58=KEYBOARD CTRL+SHIFT+o+^o+^SHIFT+^CTRL key30=KEYBOARD CTRL+SHIFT+p+^p+^SHIFT+^CTRL key45=KEYBOARD CTRL+SHIFT+a+^a+^SHIFT+^CTRL key27=KEYBOARD CTRL+SHIFT+s+^s+^SHIFT+^CTRL key15=KEYBOARD CTRL+SHIFT+d+^d+^SHIFT+^CTRL key60=KEYBOARD CTRL+SHIFT+f+^f+^SHIFT+^CTRL key23=KEYBOARD CTRL+SHIFT+g+^g+^SHIFT+^CTRL key28=KEYBOARD CTRL+SHIFT+h+^h+^SHIFT+^CTRL key37=KEYBOARD CTRL+SHIFT+j+^j+^SHIFT+^CTRL ;key61=KEYBOARD CTRL+SHIFT+F5+^F5+^SHIFT+^CTRL ;key59=KEYBOARD CTRL+SHIFT+F6+^F6+^SHIFT+^CTRL ;key63=KEYBOARD CTRL+SHIFT+F7+^F7+^SHIFT+^CTRL ;key62=KEYBOARD CTRL+SHIFT+F8+^F8+^SHIFT+^CTRL ;key26=KEYBOARD CTRL+SHIFT+c+^c+^SHIFT+^CTRL ;key22=KEYBOARD CTRL+SHIFT+r+^r+^SHIFT+^CTRL key61=KEYBOARD LEFT+^LEFT key59=KEYBOARD RIGHT+^RIGHT key63=KEYBOARD UP+^UP key62=KEYBOARD DOWN+^DOWN key26=KEYBOARD ENTER+^ENTER ;key22=KEYBOARD ESC+^ESC ;key22=KEYBOARD BACKSPC+^BACKSPC key22=KEYBOARD BACKSPC+^BACKSPC key39=KEYBOARD CTRL+SHIFT+v+^v+^SHIFT+^CTRL key21=KEYBOARD CTRL+SHIFT+b+^b+^SHIFT+^CTRL key13=KEYBOARD CTRL+SHIFT+n+^n+^SHIFT+^CTRL key11=KEYBOARD CTRL+SHIFT+m+^m+^SHIFT+^CTRL key14=KEYBOARD CTRL+SHIFT+k+^k+^SHIFT+^CTRL ; FAST FORWARD not working key07=KEYBOARD CTRL+SHIFT+l+^l+^SHIFT+^CTRL key38=KEYBOARD CTRL+SHIFT+F1+^F1+^SHIFT+^CTRL key41=KEYBOARD CTRL+SHIFT+F2+^F2+^SHIFT+^CTRL key42=KEYBOARD CTRL+SHIFT+F3+^F3+^SHIFT+^CTRL key24=KEYBOARD CTRL+SHIFT+F4+^F4+^SHIFT+^CTRL key49=KEYBOARD CTRL+SHIFT+1+^1+^SHIFT+^CTRL key50=KEYBOARD CTRL+SHIFT+2+^2+^SHIFT+^CTRL key51=KEYBOARD CTRL+SHIFT+3+^3+^SHIFT+^CTRL key52=KEYBOARD CTRL+SHIFT+4+^4+^SHIFT+^CTRL key53=KEYBOARD CTRL+SHIFT+5+^5+^SHIFT+^CTRL key54=KEYBOARD CTRL+SHIFT+6+^6+^SHIFT+^CTRL key55=KEYBOARD CTRL+SHIFT+7+^7+^SHIFT+^CTRL key56=KEYBOARD CTRL+SHIFT+8+^8+^SHIFT+^CTRL key57=KEYBOARD CTRL+SHIFT+9+^9+^SHIFT+^CTRL key58=KEYBOARD CTRL+SHIFT+0+^0+^SHIFT+^CTRL key1001=KEYBOARD CTRL+SHIFT+f+^f+^SHIFT+^CTRL key1002=KEYBOARD CTRL+SHIFT+q+^q+^SHIFT+^CTRL key1040=KEYBOARD CTRL+SHIFT+F2+^F2+^SHIFT+^CTRL key1041=KEYBOARD CTRL+SHIFT+F1+^F1+^SHIFT+^CTRL key1042=KEYBOARD CTRL+SHIFT+F4+^F4+^SHIFT+^CTRL key1009=KEYBOARD CTRL+SHIFT+F9+^F9+^SHIFT+^CTRL key1010=KEYBOARD CTRL+SHIFT+y+^y+^SHIFT+^CTRL key1011=KEYBOARD CTRL+SHIFT+F11+^F11+^SHIFT+^CTRL key1012=KEYBOARD CTRL+SHIFT+F12+^F12+^SHIFT+^CTRL key1006=KEYBOARD CTRL+SHIFT+w+^w+^SHIFT+^CTRL key1043=KEYBOARD CTRL+SHIFT+s+^s+^SHIFT+^CTRL key1044=KEYBOARD CTRL+SHIFT+d+^d+^SHIFT+^CTRL key1015=KEYBOARD CTRL+SHIFT+g+^g+^SHIFT+^CTRL key1016=KEYBOARD CTRL+SHIFT+h+^h+^SHIFT+^CTRL key1017=KEYBOARD UP+^UP key1018=KEYBOARD DOWN+^DOWN key1019=KEYBOARD LEFT+^LEFT key1020=KEYBOARD RIGHT+^RIGHT key1021=KEYBOARD ENTER+^ENTER key1013=KEYBOARD BACKSPC+^BACKSPC ;key1017=KEYBOARD CTRL+SHIFT+F7+^F7+^SHIFT+^CTRL ;key1018=KEYBOARD CTRL+SHIFT+F8+^F8+^SHIFT+^CTRL ;key1019=KEYBOARD CTRL+SHIFT+F5+^F5+^SHIFT+^CTRL ;key1020=KEYBOARD CTRL+SHIFT+F6+^F6+^SHIFT+^CTRL ;key1021=KEYBOARD CTRL+SHIFT+c+^c+^SHIFT+^CTRL ;key1013=KEYBOARD CTRL+SHIFT+ESC+^ESC+^SHIFT+^CTRL key1045=KEYBOARD CTRL+SHIFT+j+^j+^SHIFT+^CTRL key1008=KEYBOARD CTRL+SHIFT+a+^a+^SHIFT+^CTRL key1035=KEYBOARD CTRL+SHIFT+b+^b+^SHIFT+^CTRL key1046=KEYBOARD CTRL+SHIFT+v+^v+^SHIFT+^CTRL key1034=KEYBOARD CTRL+SHIFT+k+^k+^SHIFT+^CTRL key1036=KEYBOARD CTRL+SHIFT+l+^l+^SHIFT+^CTRL key1047=KEYBOARD CTRL+SHIFT+n+^n+^SHIFT+^CTRL key1037=KEYBOARD CTRL+SHIFT+r+^r+^SHIFT+^CTRL key1038=KEYBOARD CTRL+SHIFT+m+^m+^SHIFT+^CTRL key1039=KEYBOARD CTRL+SHIFT+t+^t+^SHIFT+^CTRL key1022=KEYBOARD CTRL+SHIFT+1+^1+^SHIFT+^CTRL key1023=KEYBOARD CTRL+SHIFT+2+^2+^SHIFT+^CTRL key1024=KEYBOARD CTRL+SHIFT+3+^3+^SHIFT+^CTRL key1025=KEYBOARD CTRL+SHIFT+4+^4+^SHIFT+^CTRL key1026=KEYBOARD CTRL+SHIFT+5+^5+^SHIFT+^CTRL key1027=KEYBOARD CTRL+SHIFT+6+^6+^SHIFT+^CTRL key1028=KEYBOARD CTRL+SHIFT+7+^7+^SHIFT+^CTRL key1029=KEYBOARD CTRL+SHIFT+8+^8+^SHIFT+^CTRL key1030=KEYBOARD CTRL+SHIFT+9+^9+^SHIFT+^CTRL key1032=KEYBOARD CTRL+SHIFT+0+^0+^SHIFT+^CTRL key1031=KEYBOARD CTRL+SHIFT+x+^x+^SHIFT+^CTRL Quote
tabbycat Posted April 27, 2007 Posted April 27, 2007 (edited) You have to insert these "key10??=KEYBOARD *+*^" entries in the [default] section (for buttons to use in all apps, e.g. UP/DOWN/LEFT/RIGHT/ENTER/numbers etc.) or an [DVBViewer] section (only for DVBV). Read the PCTVRemote-manual for the "??"-codes. If you have no clue, you can also use the settings in that post. mfg tc Edited April 30, 2007 by tabbycat Quote
Lars_MQ Posted April 27, 2007 Posted April 27, 2007 If you have no glue Oh my, DVBViewer not is made by ikea, you don't need glue or scotch tape to put it together Quote
miro111hrzg Posted April 27, 2007 Author Posted April 27, 2007 You have to insert these "key10??=KEYBOARD *+*^" entries in the [default] section (for buttons to use in all apps, e.g. UP/DOWN/LEFT/RIGHT/ENTER/numbers etc.) or an [DVBViewer] section (only for DVBV). Read the PCTVRemote-manual for the "??"-codes. If you have no glue, you can also use the settings in that post. mfg tc thank you , I will try. Quote
extremeno Posted April 29, 2007 Posted April 29, 2007 I've posted a profiles.ini definition for DVBViewer here: http://www.DVBViewer.info/forum/index.php?showtopic=18118 It's for type two remote (the largest one). I expect you can adapt it for the mini remote. You should complement this definition with appropiate key mapping in Options->Input. This is my definition: pinnacle.zip Hope this help. Regards from Spain Quote
miro111hrzg Posted April 29, 2007 Author Posted April 29, 2007 (edited) I am still trying to find out how this remote stuff works, but tabbycat's code definately works. Only I don't know where exactly to insert it in ini file. Main connection between DVBViewer and that PCremote was established by his code. I tried with matching teletext button and I get teletext. Afterwards, almost everything worked on remote,hehe but I don't know how, but then I cleared all from ini file to understand exactly how this thing work step by step but I didn't find out. I am still workin on it. I will try those ini's Edited April 29, 2007 by miro111hrzg Quote
tabbycat Posted April 30, 2007 Posted April 30, 2007 Oh my, DVBViewer not is made by ikea, you don't need glue or scotch tape to put it together g --> c mfg tc Quote
CiNcH Posted April 30, 2007 Posted April 30, 2007 (edited) Pretty difficult indeed. The codes within the PCTVMediaCenter_Remote_DE.pdf seem to be wrong, at least for the type C remote. The following keys are working for me: ; ; ; [default] ; start PMC with Remote Type A ( 2ft TV ) key38=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe ; start PMC with Remote Type A ( 10ft main menu ) ; key47=EXEC ..\..\..\PMC.exe | -10ft -full key29=EXEC ..\..\..\PMC.exe | -10ft -full ; ; start PMC with Remote Type B ( main menu ) key1006=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full ; ; start PMC with Remote Type B ( 2ft TV ) key1041=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe ; ; Autorun ;HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run autorunkey=PMCRemote ; ; hardware ID: -1 = autodetect ; 0 : COM IR ; 2 : PCTV Deluxe USB IR ; 3 : PCTV USB2 IR ; 4 : PCTV 300i Stereo PCI IR ; 5 : PCTV 100i Stereo PCI IR ; 6 : PCTV 200e USB IR ; 7 : PCTV 310i IR ; 8 : PCTV 110i IR ; 9 : PCTV 400e USB IR ; 10: Pinnacle Remote USB IR ; 11: Pinnacle 3010i IR ; 12: PCTV 60e USB IR ; 13: PCTV 310e USB IR ; 14: PCTV 7010iX IR ; 15: DVB-T USB stick IR ; 16: PCTV Dual DVB-T Pro IR ; 17: PCTV Dual Sat Pro IR ; 18: PCTV Hybrid Card IR ; 19: PCTV Sat Pro IR HWID=15 port=1 ; -------------------------------------------------- ; NEW: protocol and code mapping override ; currently used by AnyTV/ComboT platform devices ; and Gimly ; code mapping also used by Deltron IR device ; -------------------------------------------------- ; protocol={nec|pcle_rc5|pcle_rc6|pcle_rcm} ; keymap={pcle_rcm|t003_rc5|pcle_rc6} protocol=pcle_rc5 keymap=t003_rc5 rc_id1=0 rc_id2=0 rc_filter=all ; ; [DVBViewer] ; ;*************** ; Remote Type C ;*************** ; ; mute key60=KEYBOARD m+^m ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 key58=KEYBOARD 0+^0 However, it only works with the remote application that came with the stick (CD 4.11). With the latest one from the Pinnacle website it doesn't. Seems we have to find some more key codes for remote type C... Edited April 30, 2007 by CiNcH Quote
CiNcH Posted April 30, 2007 Posted April 30, 2007 (edited) ; Volume down key15=KEYBOARD LEFT+^LEFT ; Volume up key27=KEYBOARD RIGHT+^RIGHT ; channel up key23=KEYBOARD UP+^UP ; channel down key28=KEYBOARD DOWN+^DOWN The correct codes can all be found in the 'Remote Type A' section of the first post in this thread (for remote type C). If you want I can provide the remote application that works for me. [edit] I just found out, that the Pro has a different mini remote, which is of type B. [/edit] Edited April 30, 2007 by CiNcH Quote
miro111hrzg Posted May 16, 2007 Author Posted May 16, 2007 I tried with this codes, I typed a lot of them manually it's for mini pinnacle remote type c. and everything works but I have small problem betwen switching from teletext back to tv window mode. Namely, when I exit the teletext window, program don't react anymore. here is the code I am using: ; ; ; [default] ; start DVBViewer with Remote Type A ( 2ft TV ) key47=EXEC C:\Program Files\DVBViewer\DVBViewer.exe | -10ft -full ;teletext key41=KEYBOARD v+^v ; ; start PMC with Remote Type B ( main menu ) key1006=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full ; ; start PMC with Remote Type B ( 2ft TV ) key1041=EXEC C:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe ; ; Autorun ;HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run autorunkey=PMCRemote ; ; hardware ID: -1 = autodetect ; 0 : COM IR ; 2 : PCTV Deluxe USB IR ; 3 : PCTV USB2 IR ; 4 : PCTV 300i Stereo PCI IR ; 5 : PCTV 100i Stereo PCI IR ; 6 : PCTV 200e USB IR ; 7 : PCTV 310i IR ; 8 : PCTV 110i IR ; 9 : PCTV 400e USB IR ; 10: Pinnacle Remote USB IR ; 11: Pinnacle 3010i IR ; 12: PCTV 60e USB IR ; 13: PCTV 310e USB IR ; 14: PCTV 7010iX IR ; 15: DVB-T USB stick IR ; 16: PCTV Dual DVB-T Pro IR ; 17: PCTV Dual Sat Pro IR ; 18: PCTV Hybrid Card IR ; 19: PCTV Sat Pro IR ; 20: PCTV 260e USB IR ; 21: PCTV Sat Pro USB IR ; 22: PCTV HDTV Sat Pro USB IR HWID=24 port=1 ; -------------------------------------------------- ; NEW: protocol and code mapping override ; currently used by AnyTV/ComboT platform devices ; and Gimly ; code mapping also used by Deltron IR device ; -------------------------------------------------- ; protocol={nec|pcle_rc5|pcle_rc6|pcle_rcm} ; keymap={pcle_rcm|t003_rc5|pcle_rc6|mini_rc5|pcle_rc5} protocol=pcle_rc5 keymap=mini_rc5 rc_id1=0 rc_id2=0 rc_filter=1 [teletext] ;close teletext window key11=KEYBOARD ALT+F4 ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 and AV selector key58=KEYBOARD 0+^0 ; ; ; [DVBViewer] ; ;*************** ; Remote Type C ;*************** ; ; key60=KEYBOARD m+^m ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 key58=KEYBOARD 0+^0 ; Volume down key15=KEYBOARD LEFT+^LEFT ; Volume up key27=KEYBOARD RIGHT+^RIGHT ; channel up key23=KEYBOARD UP+^UP ; channel down key28=KEYBOARD DOWN+^DOWN ;recording key39=KEYBOARD r+^r ;teletext key41=KEYBOARD v+^v ;**************************** ; Remote Settings for HTML Plugin interface ;**************************** [Pinnacle MediaCenter] key47=KEYBOARD CTRL+SHIFT+q+^q+^SHIFT+^CTRL key29=KEYBOARD CTRL+SHIFT+w+^w+^SHIFT+^CTRL key25=KEYBOARD CTRL+SHIFT+e+^e+^SHIFT+^CTRL key19=KEYBOARD CTRL+SHIFT+t+^t+^SHIFT+^CTRL key46=KEYBOARD CTRL+SHIFT+z+^z+^SHIFT+^CTRL key31=KEYBOARD CTRL+SHIFT+u+^u+^SHIFT+^CTRL key43=KEYBOARD CTRL+SHIFT+i+^i+^SHIFT+^CTRL ;key58=KEYBOARD CTRL+SHIFT+o+^o+^SHIFT+^CTRL key30=KEYBOARD CTRL+SHIFT+p+^p+^SHIFT+^CTRL key45=KEYBOARD CTRL+SHIFT+a+^a+^SHIFT+^CTRL key27=KEYBOARD CTRL+SHIFT+s+^s+^SHIFT+^CTRL key15=KEYBOARD CTRL+SHIFT+d+^d+^SHIFT+^CTRL key60=KEYBOARD CTRL+SHIFT+f+^f+^SHIFT+^CTRL key23=KEYBOARD CTRL+SHIFT+g+^g+^SHIFT+^CTRL key28=KEYBOARD CTRL+SHIFT+h+^h+^SHIFT+^CTRL key37=KEYBOARD CTRL+SHIFT+j+^j+^SHIFT+^CTRL ;key61=KEYBOARD CTRL+SHIFT+F5+^F5+^SHIFT+^CTRL ;key59=KEYBOARD CTRL+SHIFT+F6+^F6+^SHIFT+^CTRL ;key63=KEYBOARD CTRL+SHIFT+F7+^F7+^SHIFT+^CTRL ;key62=KEYBOARD CTRL+SHIFT+F8+^F8+^SHIFT+^CTRL ;key26=KEYBOARD CTRL+SHIFT+c+^c+^SHIFT+^CTRL ;key22=KEYBOARD CTRL+SHIFT+r+^r+^SHIFT+^CTRL key61=KEYBOARD LEFT+^LEFT key59=KEYBOARD RIGHT+^RIGHT key63=KEYBOARD UP+^UP key62=KEYBOARD DOWN+^DOWN key26=KEYBOARD ENTER+^ENTER ;key22=KEYBOARD ESC+^ESC ;key22=KEYBOARD BACKSPC+^BACKSPC key22=KEYBOARD BACKSPC+^BACKSPC key39=KEYBOARD CTRL+SHIFT+v+^v+^SHIFT+^CTRL key21=KEYBOARD CTRL+SHIFT+b+^b+^SHIFT+^CTRL key13=KEYBOARD CTRL+SHIFT+n+^n+^SHIFT+^CTRL key11=KEYBOARD CTRL+SHIFT+m+^m+^SHIFT+^CTRL key14=KEYBOARD CTRL+SHIFT+k+^k+^SHIFT+^CTRL ; FAST FORWARD not working key07=KEYBOARD CTRL+SHIFT+l+^l+^SHIFT+^CTRL key38=KEYBOARD CTRL+SHIFT+F1+^F1+^SHIFT+^CTRL key41=KEYBOARD CTRL+SHIFT+F2+^F2+^SHIFT+^CTRL key42=KEYBOARD CTRL+SHIFT+F3+^F3+^SHIFT+^CTRL key24=KEYBOARD CTRL+SHIFT+F4+^F4+^SHIFT+^CTRL key49=KEYBOARD CTRL+SHIFT+1+^1+^SHIFT+^CTRL key50=KEYBOARD CTRL+SHIFT+2+^2+^SHIFT+^CTRL key51=KEYBOARD CTRL+SHIFT+3+^3+^SHIFT+^CTRL key52=KEYBOARD CTRL+SHIFT+4+^4+^SHIFT+^CTRL key53=KEYBOARD CTRL+SHIFT+5+^5+^SHIFT+^CTRL key54=KEYBOARD CTRL+SHIFT+6+^6+^SHIFT+^CTRL key55=KEYBOARD CTRL+SHIFT+7+^7+^SHIFT+^CTRL key56=KEYBOARD CTRL+SHIFT+8+^8+^SHIFT+^CTRL key57=KEYBOARD CTRL+SHIFT+9+^9+^SHIFT+^CTRL key58=KEYBOARD CTRL+SHIFT+0+^0+^SHIFT+^CTRL key1001=KEYBOARD CTRL+SHIFT+f+^f+^SHIFT+^CTRL key1002=KEYBOARD CTRL+SHIFT+q+^q+^SHIFT+^CTRL key1040=KEYBOARD CTRL+SHIFT+F2+^F2+^SHIFT+^CTRL key1041=KEYBOARD CTRL+SHIFT+F1+^F1+^SHIFT+^CTRL key1042=KEYBOARD CTRL+SHIFT+F4+^F4+^SHIFT+^CTRL key1009=KEYBOARD CTRL+SHIFT+F9+^F9+^SHIFT+^CTRL key1010=KEYBOARD CTRL+SHIFT+y+^y+^SHIFT+^CTRL key1011=KEYBOARD CTRL+SHIFT+F11+^F11+^SHIFT+^CTRL key1012=KEYBOARD CTRL+SHIFT+F12+^F12+^SHIFT+^CTRL key1006=KEYBOARD CTRL+SHIFT+w+^w+^SHIFT+^CTRL key1043=KEYBOARD CTRL+SHIFT+s+^s+^SHIFT+^CTRL key1044=KEYBOARD CTRL+SHIFT+d+^d+^SHIFT+^CTRL key1015=KEYBOARD CTRL+SHIFT+g+^g+^SHIFT+^CTRL key1016=KEYBOARD CTRL+SHIFT+h+^h+^SHIFT+^CTRL key1017=KEYBOARD UP+^UP key1018=KEYBOARD DOWN+^DOWN key1019=KEYBOARD LEFT+^LEFT key1020=KEYBOARD RIGHT+^RIGHT key1021=KEYBOARD ENTER+^ENTER key1013=KEYBOARD BACKSPC+^BACKSPC ;key1017=KEYBOARD CTRL+SHIFT+F7+^F7+^SHIFT+^CTRL ;key1018=KEYBOARD CTRL+SHIFT+F8+^F8+^SHIFT+^CTRL ;key1019=KEYBOARD CTRL+SHIFT+F5+^F5+^SHIFT+^CTRL ;key1020=KEYBOARD CTRL+SHIFT+F6+^F6+^SHIFT+^CTRL ;key1021=KEYBOARD CTRL+SHIFT+c+^c+^SHIFT+^CTRL ;key1013=KEYBOARD CTRL+SHIFT+ESC+^ESC+^SHIFT+^CTRL key1045=KEYBOARD CTRL+SHIFT+j+^j+^SHIFT+^CTRL key1008=KEYBOARD CTRL+SHIFT+a+^a+^SHIFT+^CTRL key1035=KEYBOARD CTRL+SHIFT+b+^b+^SHIFT+^CTRL key1046=KEYBOARD CTRL+SHIFT+v+^v+^SHIFT+^CTRL key1034=KEYBOARD CTRL+SHIFT+k+^k+^SHIFT+^CTRL key1036=KEYBOARD CTRL+SHIFT+l+^l+^SHIFT+^CTRL key1047=KEYBOARD CTRL+SHIFT+n+^n+^SHIFT+^CTRL key1037=KEYBOARD CTRL+SHIFT+r+^r+^SHIFT+^CTRL key1038=KEYBOARD CTRL+SHIFT+m+^m+^SHIFT+^CTRL key1039=KEYBOARD CTRL+SHIFT+t+^t+^SHIFT+^CTRL key1022=KEYBOARD CTRL+SHIFT+1+^1+^SHIFT+^CTRL key1023=KEYBOARD CTRL+SHIFT+2+^2+^SHIFT+^CTRL key1024=KEYBOARD CTRL+SHIFT+3+^3+^SHIFT+^CTRL key1025=KEYBOARD CTRL+SHIFT+4+^4+^SHIFT+^CTRL key1026=KEYBOARD CTRL+SHIFT+5+^5+^SHIFT+^CTRL key1027=KEYBOARD CTRL+SHIFT+6+^6+^SHIFT+^CTRL key1028=KEYBOARD CTRL+SHIFT+7+^7+^SHIFT+^CTRL key1029=KEYBOARD CTRL+SHIFT+8+^8+^SHIFT+^CTRL key1030=KEYBOARD CTRL+SHIFT+9+^9+^SHIFT+^CTRL key1032=KEYBOARD CTRL+SHIFT+0+^0+^SHIFT+^CTRL key1031=KEYBOARD CTRL+SHIFT+x+^x+^SHIFT+^CTRL Quote
tabbycat Posted May 17, 2007 Posted May 17, 2007 key11=KEYBOARD ALT+F4 That means: You press "ALT" and then "F4", but you don't release these keys! Try this: key11=KEYBOARD ALT+F4+^F4+^ALT It's also possible to use teletext via OSD. In this case you don't need the [teletext]-section. mfg tc Quote
miro111hrzg Posted May 20, 2007 Author Posted May 20, 2007 Yes, you were right. Now it works. Thank you. Quote
miro111hrzg Posted June 30, 2007 Author Posted June 30, 2007 what should be code for - key to work with this syntax?(it's key on the right of the keyboard - numpad section) Quote
Zoli1972 Posted February 20, 2013 Posted February 20, 2013 Hi, First of all, sorry for 'warming up' this old thread. I have a Pinnacle PCTV 510e TV stick with the small remote control. The thread starter said here, that there wold be a small program called PCTV Remote that comes along with the set on the installation CD. Unfortunately, I lost my installation CD, and Pinnacle doesn't provide a download for that small program. Could someone please provide a download link for it? Thanks Zoli Quote
