How To I Exit Htpc Mode?
Cirion
I enabled HTPC-mode in General Options.
Now I can not use a mouse.... How do I exit the HTPC mode?
Can I reset all settings without loosing my channellist?
Edit Setup.xml:
<settings>
<entry name="HTPCMode">0</entry>
And add to the OSD menu the possibility to leave HTPC mode (in options).
Hello,
OSD -> htpcHome -> theSettings -> Unlock HTPC-Mode,
now you can go to options (use the mouse) and disable the HTPC-Mode.
