Wich Tv Card For Dvb-c
sepp999
Hi Pros,
can anybody recommend one of the following DVB-C PCI Cards:
TT C-1500 HDTV with CI Modul
KNC1 TV-Station DVb-C with CI Modul
DigitalRise DVB-C PCI Cable CI.
I need it for HDTV (P****HD) and the Card should of course work good with DVBViewer. If possible under Vista.
Is it possible to run 2 Cards in one computer?
Thanks,
S.
it is possible to run two cards in one computer...
be aware that DVBViewer doesn't support decryption of more than one channel per cam, so two cards is quite a good idea, but will need two smartcards...
I would stay away from the Twinhan / DigitalRise. It has serious driver issues and causes a huge latency on the PCI bus (8000µs and higher)
