miro68 Posted May 4, 2007 Posted May 4, 2007 If I want to enter "Positioner" in "DiSEqC Editor" nothing happens. I can't enter Positioner settings. The button doesn't function support.zip Quote
Lars_MQ Posted May 4, 2007 Posted May 4, 2007 most likelyit open somewhere out of you displayarea. try pressing ALT + SPACE after opening the positioner. you should see a menu somewhere on your monitor. select move and move around with the arrow keys till you see the window. Quote
miro68 Posted May 4, 2007 Author Posted May 4, 2007 (edited) I tried ALT + SPACE but it shows as DiSEqC Editor menu (close function on the menu closes DiSEqC Editor) If Positioner Console would show somewhere I couldn't close DiSEqC Editor window before closing Positioner Console but I can. It shows that Positioner Console doesn't show at all. With some older version all works good (DVBViewer 3.6.0.2) I reported it some time ago but without support.zip file. Edited May 4, 2007 by miro68 Quote
mr_chaela Posted May 4, 2007 Posted May 4, 2007 If I want to enter "Positioner" in "DiSEqC Editor" nothing happens.I can't enter Positioner settings. The button doesn't function. Same here, I thought this was a known problem with versions 3.6.1.2 & 3.6.1.20 Works fine on the new beta though. Quote
miro68 Posted May 4, 2007 Author Posted May 4, 2007 Same here, I thought this was a known problem with versions 3.6.1.2 & 3.6.1.20Works fine on the new beta though. Right, me too with 3.6.2.1 beta Quote
miro68 Posted May 8, 2007 Author Posted May 8, 2007 most likelyit open somewhere out of you displayarea. try pressing ALT + SPACE after opening the positioner. you should see a menu somewhere on your monitor. select move and move around with the arrow keys till you see the window. Is there any positioner solution for 3.6.1.20 Quote
redu Posted May 25, 2007 Posted May 25, 2007 (edited) Right, me too with 3.6.2.1 beta Yes, positioner setting seems to work in new beta. But, unfortunately, turning the motor does not take place. No effect with "goto position 31" for instance. Did I misunderstand something? Ref1: Linux Kaffeine 0.8.4 DVB-S positioner works just fine automatically according to stored position. Ref2: AltDVB 2.2 DVB-S positioner works just fine automatically according to stored position. Should some plugin be used to activate positioning in DVBViever? Equipment: Twinhan dtv 1020a dvb-s-card. HH-motor with usals and diseqc 1.2. redu Edited May 25, 2007 by redu Quote
