Lars_MQ Posted May 7, 2007 Posted May 7, 2007 I uploaded the Delphi source of a COM Input Plugin for the DVBViewer Pro into the membersarea/sources With this input plugin you can send Remotecontrol commands to the DVBViewer via COM. The use is very simple. You name your remote on first connection and you can send any string as a command. Of course you have to do the learning procedure in the DVBViewer input options. Included is a very basic demo app in VBNet which shows the use of the plugin. This Plugin shows also how easy it is to write a inputplugin for the DVBViewer. All you need is a dll which exports 6 functions (of which one is optional and 4 are static). Of course the binaries are included, in case you don't have/speak delphi Quote
cgiesen Posted August 17, 2007 Posted August 17, 2007 Hello Lars, thanks for the Demo. But I thinks in the vb demo ther are missing files!!! Regards Carsten Quote
Lars_MQ Posted August 17, 2007 Author Posted August 17, 2007 Hmm, VB does create a lot of files for a project. I attach the whole dir structure here, hopefully this is everything... DemoRemote.zip Quote
