chrispazz Posted May 9, 2007 Posted May 9, 2007 Hello! Is there any chance to use the new nvidia 8500/8600 hardware acceleration in H.264 in DVBViewer pro? Thank you Christian Quote
CiNcH Posted May 9, 2007 Posted May 9, 2007 (edited) Vista (nVIDIA driver 158.x) + DVBViewer GE + CyberLink H.264 Decoder (>= v7.2) + Enhanced Video Renderer That's currently the only working combination. Edited May 9, 2007 by CiNcH Quote
Moses Posted May 9, 2007 Posted May 9, 2007 Did anyone test EVR + WinXP + DVBViewer GE, yet? Would be quite interesting... Quote
chrispazz Posted May 9, 2007 Author Posted May 9, 2007 Vista (nVIDIA driver 158.x) + DVBViewer GE + CyberLink H.264 Decoder (>= v7.2) + Enhanced Video Renderer That's currently the only working combination. I have the same configuration like you (E6420, 2x512GB, Geforce 8500gt, TT-S2-3200). With HD content (H.264) from sat I get almost 100% cpu with a lot of stuttering. I am using Pro version of DVBViewer. is it possible that Powerdvd 7.3 codec support VMR too? I have just upgraded my hardware for HD and have just discovered that my ge8500gt is useless currently with DVBViewer pro.... thanks christian Quote
CiNcH Posted May 9, 2007 Posted May 9, 2007 Did anyone test EVR + WinXP + DVBViewer GE, yet? Tried it, yes. But it was quite hopeless as the XP driver simply lacks PureVideo support. is it possible that Powerdvd 7.3 codec support VMR too? VMR9 is supported, yes, but under Vista it is only possible to take advantage of H.264 acceleration via DXVA2 (at least with the CyberLink codec). DXVA2 can only be used together with EVR. PureVideo 2 can indeed not be accessed when using DVBViewer Pro, neither under Vista, nor under XP. However, I believe that future XP implementations (driver + decoder) will work with VMR. Quote
