Myinternet Plugin
The reason why i release the code and not the binary is that in my opinion the internet plugin is not really usefull - especially if you try to browse around with the remote.
The used keys are:
- 2,8,4,6 for scrolling inside the browser
- 5 for pressing a link resp. enter a text in a textbox
- 1,3 for selecting the prev/next element (this feature is currently disabled)
- Red Button to remove a favourite
- Green Button to add to favourite
- Yellow Button to change the start page
- Blue Button to switch between the favourite list and the browser
The code should explain you how to:
1. create an own OSD window plugin
2. request DVBViewer settings
3. deal with messages, buttons and listboxes
The delphi sources should be almost self explaining, but if you have questions feel free to ask.
Christian
myinternet.zip
First i have no experience with delphi.
By compiling i get a error SHDocVw.dcu missing how i get and import this file.
I use Delphi 2005 Personal (c`t 13/2005)
  • 4 weeks later...
Hm... I had exactly the same problem, if you look at the imported pascal files in "MyInternet.dpr" (this list is startet by "uses" in pascal), you will find the line
uskininfo in 'Units\uskininfo.pas',
This tries to import a uskinfo.pas file in Units... this file does not exists! :bye:
But I just commented it out (by adding "//" to the front of the line) and I was able to build the plugin... I didn't test it with DVBViewer, yet, to see if something is missing...
USkininfo can be removed, it is not really used in the plugin. The SHDocVw contains the IE ActiveX object and i'm quite sure it can be also found via google.
Christian
  • 1 year later...
I don't have a pascal compiler. Could you also provide a compiled version?
Thanks
  • 2 months later...
Christian,
I looked closer at your example and found a lot of interfaces that seem to be COM interfaces, but they are not available in the DVBViewerServer namespace. For example IOSDWindowManager and IOSDControl. Even if this works only inside the context of a plugin, is there a chance to get interface definitions for writing my own plugin in C++? Or do I need to re-write the data types from the Pascal code?
Are they documented somewhere?
Regards,
klaus.
  • 11 months later...
  • 1 month later...
Yes and no. You can open web Pages but at the moment it is not possible to closes the plug-in.
If you are not a developer it is not really for you.
