Bobben Posted May 13, 2007 Posted May 13, 2007 (edited) I have changed to Windows Vista Home Premium and have a problem getting DVBViewer and TransEdit to work. The USB card was detected but when I tried to tune in DVBViewer og TransEdit then the result was bluescreen. I then tried the TT Mediacenter software from Technotrend and there was an error message about a missing DVB filter. That might be the problem. Also on Technotrend there was new driver which should support Vista. I tried to upgrade but now I have got a problem with the driver. In my frustration I might have done something wrong . It looks like the driver is not working as there is a conflict with a driver with the same name. The error message says "The drivers for this device are not installed. (Code 28) The name is already in use as either a service name or a service display name." I have not been able to locate and remove the driver (or service) with the same name. TT Mediacenter detects DirectX. DirectX version is 10. support.zip Edited May 13, 2007 by Bobben Quote
Bobben Posted May 13, 2007 Author Posted May 13, 2007 It is suddenly working. Not sure what went wrong but now the driver is running and the technotrend card is working with both DVBViewer and TransEdit... Quote
