Most Of The Channels Are Not Being Decoded
Most of the channels have an asterisk next to the channel name, meaning this is encoded, though the card is present in the CI slot and the channels are being successfully decoded by the original application of TWINHAN.
Is there any other application to be loaded to enable automatic decoding by DVBViewer? I noticed that when I am using the CI program of TWINHAN and press the button "descramble" it does descramble the channel (after a while) but it does not happen automatically with DVBViewer, though it does with the native application.
Thanks in advance.
Regards,
Joeri
Try the current beta of the DVBViewer pro (membersarea -> betasection). The CI support for theTwinhan cards has been improved.
Thanks, I tried this. It works much better - it decodes the channels automatically,
but there is still problem with subtitling and teletext which are not decoded automatically, so the program shows as if no teletext and/or subtitling is available, though when I start the CI descramble programme manually as described above they are available.
Thanks in advance.
Regards,
