Benarty Posted May 18, 2007 Posted May 18, 2007 (edited) As usual, problems between devices that has no ground and a device with a grounded power supply unit. We can hear an annoying 50Hz humm in the audio signal. Are there commercial small devices (or software) that can remove the 50Hz noise ...or even other noise sources out of the audio part? Replacing the atx PSU is not an option. The system is properly grounded. Edited May 18, 2007 by Benarty Quote
