Zoom doesn't work right in fullscreen
Exel
A really weird problem: When I attempt to zoom the picture in full screen mode (eg. to manually cut out black bars from the picture) the picture doesn't stay centered but is locked to the top left corner. So when I zoom in, the picture enlargens, but only to right and down. Any black bars it had on the top or the left edge remain fixed. In windowed mode the zoom works as it should so that the image grows to all directions when zoomed.
The problem only occured after updating to V3.6.1.20.
Edit: I discovered this only happens with the VMR9 Video Renderer. When using VMR7 or Overlay Mixer it works right.
Edit II: The black bars seem to be fixed to the desktop instead of the DVBV window. If I move the player around in windowed mode, I get the black bars when I move it close the top or left edges of the screen. :bye:
Edited by Exel
I guess you have a nvidia card?
If yes try a driver version in the 80s-Range if you don´t have a card which requires a higher driver count. Newer drivers are known for such problems.
