Osd on second display with vmr
luky
Hi, i am having a problem for which I am not sure exist a solution. I was trying to find the solution in the forum, however you can't search on keywords as OSD or VMR :bye:
So what's wrong - I have Nvidia 6600GT and was using 84 series of drivers in VMR9 Fullscreen mode on my TV (second DualView display connected by Svideo/Composite) without any issue. However when I tried to watch HD stream as ANXIE HD reneder starts to drop frame madly and it was unusable. In overlay mode everything was fine except (understandably) no OSD on TV.
So I decided to try out 9x series of drivers which boast PureHD support. Indeed, you can watch HD in VMR without jerky picture with new drivers, however OSD is not displayed on secondary display.
And here is my question - is there any workaround, registry hack, whatsever which will enable OSD (VMR mixing) on TV out? So far I tried many drivers but none of them looks to solve the problem
Cheers
Luky
Hi, i am having a problem for which I am not sure exist a solution. I was trying to find the solution in the forum, however you can't search on keywords as OSD or VMR :shifty:
There is a way you can search the forum for three-letter terms -- try this:
Go to Google and type in the following in the search field:
site:http://www.DVBViewer.info/forum/ "OSD" +"VMR"
You can use the "site:" method to search for any thee-letter phrases, either singly or together (using the "+" option).
Edited by jbodin
