Detail data lost in EPG Window
HenPen
All,
After dragging down the size of the detail data section in the EPG window so small I can't see it or drag it larger again! Any ideas? Or have I missed a thread on this?
I see Lars has been working on the EPG detail section in his new beta 3.6.2.25 but installing it (copying the beta on to a copy of the original) didn't help.
-Henpen
I think there was a bug in the 3.6.1.20 which caused it. in the beta you have to go near the bottom of the window and pull the divider up.
Lars,
I get the "acordian" symbol when I hover over the bar but dragging it up doesn't work - the symbol drags up but the bar doesn't follow or appear after releasing the button. I've tried maximizing the EPG windo and changing its size but nothing.
Its not critical - I wanted to see your work on this part of DVBV. I've been using TVTV.de to see program descriptions and what's on. I like their layout and customization (and I wish there was a widget to DVBV for recording).
  • 3 weeks later...
I found the the configuration for the stuck divider bar (and lots of other config settings) in setup.xml in the configuration folder. I found the bad entry for the divider and I can see the program descriptions now. Just deleting setup.xml would have set it back to the defualt I assume...Henpen
