lateko Posted May 26, 2007 Posted May 26, 2007 to be short: Is there a way to view and delete recordings other than osd? If I delete recordings manually through windows explorer, they still show in osd reconrdings list... Quote
HenPen Posted May 26, 2007 Posted May 26, 2007 If you have the Tool bar visible (View - Show toolbar) you'll see the DVBViewer pull-down. Select "Record settings" and you should see all your recordings listed and manageable. -Henpen Quote
hdv Posted May 26, 2007 Posted May 26, 2007 Hello, in the newes Beta Version is a new window "Recordings- and Device Status" (click) Quote
lateko Posted May 27, 2007 Author Posted May 27, 2007 Thanks for the answers. Maybe I'll give beta a go. "Record Settings..." menuitem doesn't do the trick for me, since it seems to show only timed forthcoming recordings, not the ones already recorded. Quote
Moses Posted May 27, 2007 Posted May 27, 2007 you can refresh the recordings database in the options. Quote
lateko Posted May 27, 2007 Author Posted May 27, 2007 But that doesn't do anything to me (at least anything i'm looking for). Finished recordings do always show when i go to osd->recordings, and never anywhere else. Should they be seen for examples through menuitem "DVBViewer"->"Record Settings"? Quote
