Djiraan Posted May 28, 2007 Posted May 28, 2007 (edited) I've been using DVBViewer + DVBServer for two weeks and I'm having a few problems. The main one is the server's stability: whenever there's a problem with the connection between the server and the client (say: wireless connection dropped; the computer where the client is goes to hibernation or suspension; the client hangs up [yeah, I can do that!, don't ask how!]), the server is unable to detect the problem and continues streaming. To make the server work again I have to close and restart it (stop+start doesn't work), which is a bother since I have to remote admin, etc. I think the problem is that the server don't detect that the client has been disconnected, and a further problem is that the server can't kick a client if the client is not there to be kicked. P.S.: Just added the support.zip file (I don't think it will be of any help in this case, though) support.zip Edited May 28, 2007 by Djiraan Quote
Djiraan Posted May 28, 2007 Author Posted May 28, 2007 (edited) multicast or unicast streaming? Unicast. Should I try multi? Edited May 28, 2007 by Djiraan Quote
Lars_MQ Posted May 28, 2007 Posted May 28, 2007 what does the server show on the first page? (connected clients etc) Quote
Lars_MQ Posted May 28, 2007 Posted May 28, 2007 Should I try multi? No multicast is connectionless (at least the streaming part) it will never notice the missing of an receiving end. Quote
Djiraan Posted May 28, 2007 Author Posted May 28, 2007 (edited) what does the server show on the first page? (connected clients etc) Well, it shows the client (that has already been disconnected) as connected. If I reconnect using the same computer, then it shows the name of the computer twice: the one that was disconnected and the new one. If I'm lucky, I can continue to watch the same channel I was watching before and (with a little more luck) others channels in the same transponder (if I try to change the transponder the client hangs up). If I'm not lucky, well, once it completely hung up my laptop with a frozen screen and a continuous noise . If I reconnect using another PC, the client that was disconnected still appears and the symptoms are the same: I can watch the same channel but better not try anything else. P.S.: Thanks for your fast reply Edited May 28, 2007 by Djiraan Quote
Djiraan Posted May 29, 2007 Author Posted May 29, 2007 Just a few screenshots to illustrate the point. The first two are from when a connection is dropped, the other two are from when I reconnect without restarting the server. Quote
