Anamorphic distorsion
extremeno
Hi everybody:
I would appreciate a new horizontal control in "Size and Position window" which controls the anamorphic distorsion level: that is: the ability of expand the sides of the image and collapse the center of it
With this feature, one can adjust 4:3 rendering in a 16:9 screen and viceversa without black bars and with minimun overal distorsion.
There's only one HTPC applicaction in wich I've seen this feature: MyTheatre, so I think it can be implemented in DirectX, and would add DVBViewer a new added value. On the other hand, It's a common feature in 16:9 TV sets, usually known as "Panorama view".
Thanks in advance
Edited by extremeno
