ylber Posted May 29, 2007 Posted May 29, 2007 1.When i Press the DVBViewer osd favorites buttom, 2.I select a channel then cancel on Osd window, 3.after that I press again the favorites buttom the window appears but not on the same channel position from last access in the favorites menue is ther gonna be a change on this issue ? or is there another solution ? thanks Quote
w8andc Posted June 12, 2007 Posted June 12, 2007 Yes, it is always very annoying to scroll to the point where you left the OSD favourite list or channel list. It would be great to have this option in DVBViewer. In my opinion logical to have it as a standard option. Quote
Lars_MQ Posted June 12, 2007 Posted June 12, 2007 Don't understand. If I select a channel in the OSD channel list, close it and reopen it the currently shown channel is focused. Works also for favorites. Quote
ylber Posted June 17, 2007 Author Posted June 17, 2007 Don't understand. If I select a channel in the OSD channel list, close it and reopen it the currently shown channel is focused. Works also for favorites. I installed a fresh windows xp and a totally new install of DVBViewer Version: 3.2.6 evey time I go back to favorites osd menue or I press F7 it comes back on the favorites list but not in the last zaped favorites subfolder, i also tried the last beta DVBViewer Pro 3.6.3, same thing can you verify please thx Quote
tjf Posted June 19, 2007 Posted June 19, 2007 I can confirm. I have many folders in my favorites (for each satellite one) and when I go there through OSD I always have to browse from the root position. It would be convenient if the last opened folder with currently tuned channel showed up right away. Tomas Quote
mlehtola Posted August 2, 2007 Posted August 2, 2007 (edited) Timeline has similar small "problem"; Let's say I have 10 channels on my favorite list and choose to watch channel 9. Then I open Timeline You think you will see all your channels...NO, you see only 9 and 10, frustrating to use the "show all" every time for example to record something from channel 2 Edited August 2, 2007 by mlehtola Quote
mlehtola Posted August 3, 2007 Posted August 3, 2007 Simply scroll up. You're the ! That was the tip of the month, thanks. Quote
