Display Mini EPG with remote
I use the an MCE remote. At present the "i" (information) button calls up the main OSD window (timeline, recordings, the music, the moves etc.
I would like to change it so that it shows mini epg e.g. epg data on the program I am currently watching. Is there anyway to configure this.
Regards
It may be easier to use the OK button, it does what you want. Otherwise you have to add a custom command to the input options. (Add group -> Add command and select the OSD-Show Miniepg action) and learn the key to this command.
