Diseq is not recognized?
ramonchin
Hi
I've installed a new PC in my room and after install DVBViewer (last stable), I only get PosA/OptA channels.
Wrong channels on PosA/OptB. I can't remember what I did in my previous PC where it worked.
My device is Pinnacle PCTV SAT HDTV Pro 452e.
Please help.
Thanks
Have you already tried with "Simple A" and "Simple B"?
With my DiSEqC it works far better than "PosA/OptA" & "PosA/OptB", that often block the switch...
You can also give a try setting "PosA/OptA" for the first LNB and "PosB/OptA" for the second...
I tried these but any success... Remember that worked for me 2 days ago :) Should I try a previous Transedit Scan ?? (Last doen't work either)
Thanks
I don't know, I haven't any problem with the last Transedit, but I have a SS2 card...
But what about the DVBViewer internal scan?
And is the dish cable directly connetted to you card (ie not through a top-box)?
And have you tested with another device the DiSEqC switch and the second LNB?
I've just noticed a problem on my dish... I'm going to fix that.
Thanks Gioxi!
Edited by ramonchin
