EPG UK bug
leonfgomez
Hey guys
It seems there is a bug with the EPG information for UK channels. Have a look to the attached image and please notice:
- the duplicated description of the event
- the use of two colors (black and blue)
- the incorrect calculation of the event's duration. In this case 12:45 am instead of 00:45
bye
leon
This is wanted. It normally means the broadcaster does not transmit a extended description, so the short description is copied to the extended description. This is nothing new and requested by several users long time ago.
I'll look into it. Normally only the contenttext in () should be blue.
No, it's calculated correctly, but I've overdone it with internationalization 12:45 AM = 00:45. I'll fix it.
