sound but no picture
HI I can get sound but no picture!
Same when I use dvd player to play back video files which work no pic but sound!
Jpdamigaman
Hello,
it seems that you did not installed an MPEG-2 decoder package to your system. Please install either a software DVD player (ie PowerDVD) or install the MPEG-2 decoder shipped with the product. On the installation discs with release 4.3.0 or higher the decoder is located within the folder \install\sonic on the CD volume.
BR
Sven
  • 2 months later...
You should make an Driverupdate of your Graphics Card.If you are using a nVidia Graphics Card, you should visit http://www.nvidia.com for nVidia GCs or http://www.ati.com for ATI GCs.
Your Mpeg2 Decoder could be Cyberlink Power DVD 7 Trial.
