Preview
kpanajotis
Hi!
I'm having the following problem:
In the preview function I can not select which channels are available for preview. For example when I'm watching VOX I can't have TVE in the preview window. The only options are some other german channels, which aren't even in my favourites or in the recent list.
Thanks for any help!
For Preview you could only choose the channels from the same Transponder (frequency).
Since the tuner of the majority of the sat card is only one, the preview function can work only for the channels that are transmitted from the same trasponder... and:
VOX is transmitted from 12187H
TVE is transmitted from 11785H
...so there is nothing you can do unless you have 2 tuner (ie, normally, 2 separate cards *and* 2 separate dish or a LNB Quad + a multiswitch)...
:bye:
