lout Posted June 14, 2007 Posted June 14, 2007 when i use uninstall then new fresh instat old setings are back ...how to complet uninstall thnx i use vista Quote
Tjod Posted June 14, 2007 Posted June 14, 2007 If DVBViewer is installed click on About > Info > Versionsinfo > the blue link. This is the config folder just delete it. If you start DVBViewer next time Default settings are back. Quote
