OSD program recordings scheduled: How to write title?
Fabien44
i would like to change the default title 'Program 1', 'Program 2' of the program recordings scheduled in OSD mode.
Is it possible?
it seems as if that this is not possible in OSD, yet...
You can change the name, using the normal window "Recorder Settings".
A better way is to use the EPG to schedule your recordigns :bounce:
